1 - 2 of 2 Posts
Would anyone out there have the back half of a front fender they don't need.
Removed my front wheel today to find three of four tabs holding the chrome side pieces broken.
With any luck someone may have one or maybe locate one from a salvage yard.
My bike is a 2006 part number "61103-MCA-000ZP FENDER B (FRONT) (FOR Y181)"
If you have one let me know how much $$
Yogi
Yogi
Hey Yogi,
Good luck with this one. They are nearly impossible to find used. The new ones are $$$$. I had the same problem. I ordered some ABS cement from soewhere on the internet, but be sure to get the "black" kind. It works perfectly with the ABS material on our bikes. Just take the fender off, carefully so don't do anymore damage. On the inside of the fender scrape any paint down to the black plastic and apply a good coat of the cement on both sides of the crack and form a bridge over it. When it cures it will be like a solid piece. Mine is holding good, so far. Hope this helps. Much cheaper than a fender, and you can't even see it when your finished. Note: I would use some ABS cleaner or acetone to clean it before glueing.
Mark in MS
1 - 2 of 2 Posts
