I am trying to get the part numbers for some clips and screws for the lower cowl that holds the foglights. I cannot find it on the HDL website fiche. Anybody know what section I should look at? I have tried almost every section and still have not found it.
go to babbiits online they have an online fische and look under cowl in the parts. i need the same stuff for mine they are based in mich i think and im not sure on how long it would take to get the hardware but it will give you part no.s to give to your local dealer james
Nope, sorry. The lower cowl is not shown under cowl, just the upper cowl and associated plastic, at least that is how it is on the HDL website for both 2001 and 2004 models. Hence the question.
Lol , Jack put your glasses on , you will find it on the far right side of the screen ;)
Here is the list of the part numbers even
12 COWL, FR. *NH168M*
64302-MCA-000ZA 001 $69.78
13 COWL, CENTER *NH1Z*
64501-MCA-000ZA 001 $154.52
14 COWL, R. *NH1Z*
64502-MCA-000ZA 001 $191.60
14 COWL, R. *R274M*
64502-MCA-000ZJ 001 $222.43
14 COWL, R. *RP166M*
64502-MCA-000ZL 001 $244.33
14 COWL, R. *R287M*
64502-MCA-000ZM 001 $209.14
14 COWL, R. *R288*
64502-MCA-000ZN 001 $244.33
14 COWL, R. *Y181P*
64502-MCA-000ZP 001 $209.14
14 COWL, R. *NHA29*
64502-MCA-000ZQ 001 $209.14
15 COWL, L. *NH1Z*
64503-MCA-000ZA 001 $191.59
15 COWL, L. *R274M*
64503-MCA-000ZJ 001 $222.43
15 COWL, L. *RP166M*
64503-MCA-000ZL 001 $244.33
15 COWL, L. *R287M*
64503-MCA-000ZM 001 $228.03
15 COWL, L. *R288*
64503-MCA-000ZN 001 $244.33
15 COWL, L. *Y181P*
64503-MCA-000ZP 001 $209.14
15 COWL, L. *NHA29*
64503-MCA-000ZQ 001 $209.14
16 PLATE, HEADLIGHT
64517-MCA-000 001 $2.50
17 NUT, COWL (UPPER)
66871-KY2-700 002 $2.50
18 SCREW (5X12)
90105-MB1-000 002 $2.50
19 SCREW, PAN (6X11)
90106-KY2-701 004 $2.51
20 SCREW, PAN (6X14)
90107-MM5-000 001 $2.77
21 SCREW, SPECIAL (6MM)
90137-MCA-000 002 $2.50
22 NUT
90305-SH3-000 002 $2.98
23 NUT, SPRING (5MM)
90320-GE2-760 006 $2.50
24 NUT, SPRING (6MM)
90320-MM5-000 002 $2.50
25 NUT, SPRING (6MM)
90320-747-000 001 $2.50
26 CLIP, SPLASH
90657-SB0-003 004 $2.50
27 NUT, CLIP (5MM)
90677-KAN-961 004 $2.50
28 CLIP *NH1*
91549-MW0-790ZA 008 $2.51
29 BOLT-WASHER (6X30)
93404-06030-07 002 $2.50
30 SCREW, TAP (4X10)
93903-24280 022 $2.50
31 SCREW, TAP (5X16)
93903-25380 005 $2.50
32 BOLT, FLANGE (6X22)
96001-06022-00 002 $2.50
33 SEAL, AIR DUCT
64448-MCA-300 002 $3.70
38 CLIP, SPLASH GUARD
90653-HC4-900 002 $2.50
There are no screws associated with the cowl and the fog lights. The fog lights attach to the front of the heads/valve covers. The only screws associated with the cowl are the ones that attach it to the engine.
