Front Wheel Bounce with new E4's
4.9K views 38 replies 15 participants last post by  Goldwinger365
New-to-me '03 GL1800A.
Forks rebuilt two weeks ago to fix blown seal on left side.
ADV nickeled last night due to being frozen.
Drove for 50 miles this morning on very old E3's. Everything was great, forks worked fine, bike was settled.
Shop put on new E4's at noon. Commented on nickel but replaced it as instructed. Installed new straight screw-on valve stems for future TPMS.
Drove for 50 miles home, and noticed at low speeds a "bounce" to the front end, like a bouncing ball. WTH?
#6 ·
My 2d E-4 perfectly mounted and with beads did that at about 27mph. No freaking idea why. It's not the first time I've heard it. My tire was early on in production after they changed max cold psi value. I'm on my 3d front E-4 and it's fine. Seriously think they had a flawed batch , perhaps the balance point was wrong, causing misaligned installation. Won't notice on anything but smooth black top, or at different speeds . It's only about a 2 to 3 mph difference from what I noticed. O tab the tire for 17k, no issue.
Sent from my Moto Z (2) using Tapatalk
#7 ·
Also running max pressure helped reduce, so I used that observance as a low pressure warning. I noticed a difference between 41 and 39 psi just as my FoBo starts to alert me.
#9 ·
Try some beads if nothing else works should balance it if thats the problem
#10 ·
Great advice, thank you all!
OK, so from easiest to hardest I'll do the following:
1. Confirm the yellow dot is aligned with the valve stem.
2. Check that the bead is seated all the way around.
3. Check that the tire is round circumferentially and laterally.
4. Check that the rim is not bent.
5. Inflate to the full 41 lbs. (it looks a pound or two low because my 40# red-green-yellow tire stem is a little yellow).
6. Put in this bottle of Run-On? [nomex=on]
#14 ·
Update:
1. The yellow dot is aligned with the valve stem.
2. The bead is uniformly seated all the way around on both sides.
3. The tire is true circumferentially and laterally.
4. The rim is true on both sides all the way around.
5. The tire was very low - 30 pounds! I inflated it to 40 pounds. Test on Sunday, weather permitting.
6. I ordered two more bottles of Run-On.
Thanks for all the advice!
Reactions: rayjoe
#17 ·
Thanks for the response.
The bike rode great for 50 miles, just before the tires were replaced, so I am thinking it is/was something related to the new rubber, or something introduced during the process of changing the tires out.
#18 ·
I really surmise Dunlop had a batch with a hard spot on the tire. Just for GPs post the manufature date code. I still have my previous set as they still have about 5k left on them, I only changed to take an extended trip that wasn't going to be interrupted by a tire change out.
#19 ·
Great question.
I'll have to check later today, I recall the tech saying one of the tires was made in March of this year, and the other in November of last year, so both were relatively new.
#22 ·
Got a chance to test ride it, and the bounce seems to be gone. As it only appeared on slow cruise conditions, I'll continue to monitor it and update this thread if the proper inflation wasn't the ultimate solution.
#23 ·
I too only noticed it at a very narrow speed band around 28mph and on smooth black top. The tire wore fine too I removed them for a long trip. Never bothered me at speed. At least one other member mentioned noticing it. O think you'll be fine unless you ride with a very full cup of coffee!
#24 ·
I've narrowed it down to a speed and RPM combination, namely 40 mph at 2100-2200 RPMs. It very much feels like a harmonic between the drivetrain and the suspension, even though it presents as a bounce in the front tire.
If I could liken it to anything, it would be the feeling of the Porsche 944S with the big rubber damper disk in the clutch, and when you dump the clutch clumsily in too high a gear it "bounces" back and forth in the same way.
#26 ·
You're feeling it when it *is* amplified, at a specific RPM range. Any slower and the bike very obviously "lugs" and you shift down. Any faster and the harmonic goes away, perhaps due to centrifugal force on the front tire, or perhaps because the engine is getting into its proper power band.
#28 ·
Is your suspension OEM ??? Do you have and OEM rear spring ???
#29 ·
Thanks for the questions - I'm not 100% certain, but it's likely that the bike has the original OEM suspension front and back, which by now is soundly whooped at 53K.
Last night I moved the spring preload from 15 to 25, but I haven't had a chance to go for a test drive, and likely won't be able to until tomorrow night at the earliest.
#31 ·
If you can, with a mirror and a flash light look up at the rear spring and see if it's red or black in color.
