1 - 10 of 10 Posts
I had the Roady XM and recently purchased the Garmin2730. I transferred my Roady account to my Garmin XM account. Now when I listen to XM I have to turn the volume to 21 when before while using the Roady I had the volume set at 16. I have adjusted the volume control in my 2730 to 100%. Is there another control I'm not aware of or is this something I'll have to live with. Really, it's no problem but more of a curiosity question. Thank You.
I guess I should have said I installed the kennedy wiring harness and it is playing through my audio jack. Thanks for the reply though.
2730 garmin volume
There is an adjustment in your menu for separate (vocal instructions) ,(xm ) and (Ipod) volumes. They can start at 100% and be reduced by 10% segments individually.In my case ,the xm was too loud to clearly understand the navigation instructions in heavy traffic so I lowered the volume by 10%!
Thanks for the advice Dyama. I checked my settings and all are at 100%. I did try another helmet/headset and the volume was better in the 2nd helmet. I don't understand why the volume changed from 1 unit to the other in the 1st helmet. Oh well, I will live with what I've got.
2730 volume
You don't have to use the Kennedy equipment.
Get a noise filter from the Electicial connection
and extention for the aux line and plug into the 2730
and everything will work fine, plenty of volume
I read a lot of posts prior to buying the Kennedy harness and all I read said to use the harness. I wish I would have read I didn't need the Kennedy set before shelling out $125.00. Oh well, lol, that's my luck. If there is a post stating not to use the harness I must have missed it. Thanks for the post Whiskers.
Re: 2730 volume
Can you elaborate on the noise filter?? Where do you get it and where do you plug it inline?? Do I buy a noise filter and plug my feed from my XM Radio into that and then plug that into the Aux input of my Autocom Super Pro AVI??? Thanks.
Re: 2730 volume
Check it out...here: http://www.electricalconnection.com/audio/filter.htm
I am looking to buy a device that allows me or my passenger to mute their mics so as not to cause interference with the music if you are singing or smoking or coughing, etc. and I have heard that mic-mutes has such a device. I need it for an Autocom Super Pro AVI Intercom System. Anyone know of anyone else who does this type of muting???
1 - 10 of 10 Posts
