Where do you guys find the button to replace the keyed lock so I can open my gas door a little easier. I've looked at DLP and Wingstuff both, but haven't found anything. Thanks for the help.
Gas Door
There is no button. You can make another key, cut it off and glue it to a knob and then leave it in the gas door. There are instructions on the board if you do a search for them.
Resident BBQ Expert
hal sells road trip essentail colormatched radio knobs
they blend right in and cover the dumb chrome of the key lock
use one for the gas door, and the other for the right pocket
HDL has the stock knobs here: KNOBS . Just get a couple Axxess 27 keys cut and saw them off at the correct length then JB weld them to the knob.
Fred's instructions are here: Instructions - he uses a knob from Lowes that is a buck or two cheaper.
.....or use a small wire tie around the plunger so the door won't latch when closed.
Sleddog
