Hi all, this is my 2nd attempt at posting so apologize if you are seeing double. Ready to throw a match at this thing after 3 hours of tugging. Took four screws out holding the air box in to move it forward enough for the front tank tags to clear. Had to cut a hose to get it off the tank so now have to get the tank out to replace the hose that I assume goes to the carb. Left rear tank corner just wont clear the wiring harness. I can't even move it out of the way. Shifting the tank forward isn't enough Do I also need to remove the fuse panel? Attached pics showing tank is tilted up I the front. I am not able to get the left rear corner out to roll the tank so right rear can clear the frame. On my first attempt at making this post it failed while I was trying to attach pic so this time will save the thread and then try to attach the pics. Hoping those that have been here before might remember a trick or tip that worked for them. Thanks, Mike. Wits end in Oregon WI.
