  • Hey everyone! Enter your ride HERE to be a part of this month's Ride of the Month Challenge!
1 - 3 of 3 Posts
Hooked up gear indicator to red 4 prong plug. It is the only one I could find under the seat. The plug is suppose to be for checking the ECM. The plug I hooked it up to was behind the relay box. Is that the right one? It is suppose to light up when ignition switch is on but it does nothing. I need to know if I have the right plug.
Sounds like you got the right one. As far as I know that is the only loose one down there. Make sure it gets good contact in the socket. A little dieclectric grease might help. I have one on my 06 for over 3yrs now with no problems.
I found the problem. One of the male prongs was bent and was going on the wrong side of the guide. Every thing works OK now.
Old Fred
1 - 3 of 3 Posts
