Hello everyone,
Purchased a nice set of those LED driving lights for the 2014 wing. Install wasn't too bad however they do not come on when ignition activated. Read I need to insert a jumper plug, which I have in the kit. Problem is "Where do I plug it in"? Has anyone installed these lights and have it set up to come on always??? Thanks for the help - Al
Brand of lights? Where did you get them?
Hello everyone,
Right behind the radio control head, black plug inside of a clear boot.
WP_20140314_16_29_30_Pro.jpg Here is a set of 960 from Bikmp3 so far have not had the law stop me for them being too bright. They do come on with the ignition.
Chard Member
Did you install on/off switch? Probably won't work with high beams. Using jumper will low use on high. I'm guessing cause I don't have a clue what lights or switch you have.
Sent from iPhone
