1 - 3 of 3 Posts
Grumpy Fart
RF pads (hand brake) appear to be hanging.
When I did a total brake job this winter I cleaned and lubed the pistons prior to retraction. They all popped up and down like a wack a mole.
Vac'd the reservoir prior to bleeding.
Must have a problem with the master cylinder.
Part numbers?
You did clean/grease the slider pins on the caliper correct?.
Chek the tiny hole in the bottom of the master cyl.they are known to plug up and not allowing the pressure to back off into the master.
1 - 3 of 3 Posts
