I replaced the battery on my 1800, turn key and engaged the switch to start but nothing. ALL dash lights and surrounding lights function but nothing happens when I engage the starter. Any suggestions?
Might be a dirty clutch lever switch. Mine did the same thing. Tried to start it in gear with the kickstand up and no start. Let the clutch lever out and then pulled it in then it started. Took the switch off cleaned it with electrical contact cleaner spray and it’s been good to go every since.Just happened to me today. I went to Sam's club, parked it in gear as usual and on the side stand.
I put up the kickstand, pulled in the clutch and NOTHING. All lights normal. I checked the usual, but decided to put it in Neutral, and she started just fine.
It wasn't the Kill Switch, Side Stand, or anything else like that. Possibly, I may not have pulled the clutch in far enough....at least, that was my suspicion.
That was the only difference, so there must be a switch associated with that.....I'll read up on it this winter. Has anyone else experienced that ?
You likely pulled the clutch in far enough.... the clutch does have a switch behind it that, if dirty or defective, will fail. This switch is required to start the bike in gear and if it fails, the bike thinks you are trying to start the bike in gear and the clutch out... Common problem and likely all you need to do is pull this switch, one screw, and clean it with some contact cleaner.Just happened to me today. I went to Sam's club, parked it in gear as usual and on the side stand.
