1 - 20 of 38 Posts
Has anyone found a good air compressor that will fit in the area in which the CD player would normally be located on the GL1800? If so where might you have found it.
This is a great board ..... I have found so much useful information here from you guys and gals......
Thanks......Looks like Savior 250 air compressor is soon to be made for the Gl1800...if the coming soon is correct. Sure didn't take you guys long to supply the answer I was looking for. You almost get the answer before the question is asked...LOL Thanks again
After looking at the pix, I went ahead and purchased it anyway, knowing
that I could make it work. It is mounted under the shelter with the outlet
mounted in the fuel door.
Other than the shelter removal/installation time involved, took about 15
minutes, and I was good to go :)
The Savior 250 looks just like the pump I bought at Walmart for $9.99 and took the case off of. Add a few wires and a switch and it is.
I could not find the cost on the Savior 250 website. Any idea how much, just for grins?
Ditto :!: :!:
lightley seasoned member
I'm thinking alot of us are in the wrong business..............
John
I think it was about $180.00 or so. I know it is a igh price, but it was a
money-back if not satisfied, and I am :)
It is quiet, not noisey like the Wal-Mart unit, tried it, noisey and failed
(before a trailer tire was inflated) very fast. All of the parts included are
high-quality, not cheap chinese crap.
Just for general info...
I just took a jaunt to my neighbors house, and borrowed his Campbell
Hausfield compressor, $10.00 @ Wal-Mart, deflated my rear tire, and put
it to work.
Then I deflated the tire again, and used the Savior 250 to inflate.
The Wal-Mart unit took 13 minutes, Savior 250, 4 minutes +/- a few
seconds. So... $10.00, did the job but 3x as long, and if it 90 degrees in
the shade, I'll pay a bit extra for a 4 minute inflate :)
Keep in mind, it is a permanent mount, and the hose is about 10ft long, so
no issues with unloading the trunk etc. I guess convenience does have a
value, the question is, just how much.
it to work.
For me... no where near $170
I use the Walmart version for my quads. Was a literaly life saver for three guys on our last trek thru Hatfield-McCoys.
Harbor Freight has 2 of the 12 volt compressors. One of them actually looks like a quality unit, on the computer screen, that is.
I'll try to get the link right:
http://www.harborfreight.com/cpi/ctaf/d ... mber=93186
It's a little heavy at 11 pounds, but can probably be trimmed down a bit. I wonder if that is the shipping weight (including the packaging). :?
I have an idea :idea: Why don't we do a compressor guts comparison like that website that cuts open oil filters. We could all pull the covers off our little compressors, take photos, then post them here. I think it would be interesting to see how similar or disimilar the guts of the various compressors appear to be. I know it wouldn't prove anymore than it did about the oil filters but would be interesting all the same. All I need is a good free, online place to store photos so I can link to them..
mcb,
How about if we get all of the ones that don't work well or have failed and pull THEM apart. If they are cheap ones, like about $10, it probably would fail after a few inflates anyway.
I don't know about the free place to store photos. I'm not into the digital thing that much.
That one from HF looks like it could tuck into a saddlebag reasonably well.
Use some of that 10' of battery wire (#4?) to run a couple wires direct from the battery to an outlet that would match up to a new plug on the compressor.
Replace the coiled hose with some 1/4" hose that wouldn't take up as much room.
Hmmmm :?
1 - 20 of 38 Posts
