1 - 20 of 29 Posts
Hi gang, I have a 2006 gl 1800 wing and I am getting ready to change oil. Anybody have part numbers or advice for oil filters??? Ive went to napa and a few other places to check on filters and found out they carry bike filters but do not have a listing for a 2006 wing. Any ideas??? thanks
Here is what I have. I think these are accurate. There are 2 numbers for some of these. They are because the diameter and thread size are the same but some are longer than stock.
I prefer the longer filter myself. It's about a half inch longer than the hondaline one, so it has more filter area inside. I didn't have any trouble installing, but some people say the wrench that fits over the end of the filter won't clear if you use the long one. Again, I don't use that type of wrench, so I didn't have any trouble. I have a small strap wrench. I also have a Tulsa Belly Pan Cover and don't have a problem there.
Purolater - L14620 or L14612
Mobile One - M1-110 or M1-108
Bosch - 3323 or 3300
AC Delco - PF2135
Honda 15410-MCJ-000
K&N KN-204
Napa Gold - 1358
STP SMO17
ST6607 or ST7317 (long)
The two filters he is refering to are also both Hondaline - the long one is the one used on the 1500, the short one is for the 1800. Both fit the 1800, and the longer one has more filter area. They are the same filter that also fits a Kawasaki 1200 Voyager, a Mazda, and a Honda CRV.
Here are some of your choices:
These Oil Filters have 20 x 1.5mm threads, 14 psi by-pass valve, anti-drain back valve, 2.3" O.D. gasket 2.5" to 3.5" long.
If you have the room, I recommend the longer filters.
Motorcycle Filters. None are recommended.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
Recommended filters. All have superior filtering.
About 2.5 inches long.
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12. Made by Champion.
Bosch 3300, about $6. Made by Champion.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10. Made by Champion.
Bosch 3323, about $6. Made By Champion.
WalMart SuperTech ST7317, about $2. Made by Champion.
Automobile Filters, about 2.5 inches long.
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Automobile Filters, about 3.25 inches long.
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Fram Double Guard DG7317
Fram PH7317
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
And when all the smoke clears, I just order a dozen at a time of the Honda OEM filters from HDL. Just easier.
wix makes napas oil filters, excellent filter. i use them on my 3 diesel trucks, forklift, wing, beemer bike etc.prefer wix as they are the manufacturer in the first place.
Honda OEM filter...just use it...BUT..use Amsoil...10W40...Motorcycle Oil...lol :D
2016 f6b
I.R.HARRY,Not nick picking ,but I had a kawasaki voyager 1200 and it had a internal filter.By the way I use thePureONE,PL14610.Its about 6 bucks and in my opinion the best on the market.But thats just from what I have read :lol: .Have a great day and you can't go wrong with the factory one.
If the problem with finding a listing is that they don't have a book that shows the '06 GW, it's the same from the '01 GW on.
Most people are using the OEM filter or the K&N. WalMart has a filter (Super Tech ST7317) that has been given good reviews.
The board sponsor has OEM filters for $7 each. I think the K&N from HDL is $13 each.
Legend in His Own Mind
Hey Mike,
Just get with Bulldog, he's a member here. He'll send you everything you need. It's quick and he'll give you a discount for being a member. He distributes Amsoil products that are among some of the best in synthetic lubricants and is a heck of a good guy. Bulldog will usually send you the ole elusive crush washer with an order too. T.
I believe Honda's wrench report for mechanics had a warning NOT to use 1500 filters on the 1800's. Why, I do not remember.
Why potentially void your warranty by using a filter you "heard" works, to save....how much money?
The recommended 15410-MCJ-003 (used on fuel injected bikes) will be the only filter to touch my bike while I own it.
Joe
I second that. Why fool around with aftermarket stuff? The cost difference is negligable in the whole scheme of things.
This, coming from a Triked bike owner??????
fILTERS
On My GL1800, FJR1300,CBR1100XX I use the SuperTech 6607 Which Cross reference's to a Mazda MX5 Miata
On my FLHR, R1150RT and Indian Scout, I use SuperTech 3614 which Cross references to a 2000 Toyota Camry V6
My bikes have used these "car filters' for a combined total of 325,000 with no signs of engine failure of oil problems..
At $2.07 each, I'm sure I saved a few dollars over the year....
Lol... How true. Let's screw around with the D.O.T. approved design of the bike, but only use OEM filters..
:lol:
I took my bike in to have some work done on it. The mechanic saw the Fram filter on it and warned me about engine problems due to filter failure. He didn't recommend Fram. Who knows what he would have said if he saw one of the other named non-Honda filters. I said thanks, not wanting to get into a debate.
Now I've never had a car, suv, van, or bike have an engine failure due to the oil filter being the cause. Now with that being said, I will change my oil filter prior to taking it to Honda for any service work so that I don't give them a reason to deny me warranty work, because as we all know Mother Honda is understanding and has the BEST "stand behind the customer" warranty in the bike industry.
I change my oil filter at the beginning of Spring and every 3k after that. I'd be more concerned about sludge and thermo breakdown, then the oil filter.
I bought oil filters from Hal when he has the sale. Can't beat the price.
Thanks for the list of alternative filters, reg and long, for I am always misplacing that info.
Have never seen or heard of any such report, have used the 1500 filter for over 70,000 miles on two different 1800's. I have a Valk also and makes no sense to buy two different filters, never had one mech say to take em off or that they would not put the same one on for me. :biker: :biker: :flg: :flg: :croc:
Harry:
What is it you don't understand about the concept of apples and apples?
Your comment was pure cynicism, a thinly veiled flame, and contributed absolutey nothing to the posters question.
I wonder if you are aware that you just slapped every trike owner in the face that reads this Board. And there are hundreds of us. Maybe when your legs go bad and you can't 2 wheel anymore, you can be one of us...or you can quit riding.
Congratulations on your silly post. Nothing better to do these days?
:roll: :lol:
Ride safe
IB - you are right. Your posts were so much more illuminating...... :roll:
1 - 20 of 29 Posts
