My GL2WAY that I purchased in April squeals when transmitting and I haven't been able to figure out how to keep from doing it. I've made sure the ferrite cores were installed correctly, the unit is grounded to the FM antenna and the SWR is correct. So far I've replaced the factory style antenna I received as part of the package deal at CycleGiant.com with the OEM Honda CB antenna thinking it might have a problem, but the issue still exists. The CB unit itself will emit an audible squeal when transmitting at times, as if it's vibrating. Sometimes the squeals comes out over the headset, and sometimes it's only heard over the air. I've checked the grounding nut that grounds the CB to the interface box and it's plenty tight. I've found that if I run a ground strap from the coax connector on the CB unit to the FM antenna ground post, the squeal is almost eliminated and only squeals every other time I key the mic.
Everyting else works as it should, the unit responds to the handlebar contols and receiving is great, which seems to point to the CB/interface unit itself. I've been working on this for several weeks and am about to throw in the towel.
Any help would be appreciated.
Vince Jacobs
Vince Jacobs
