Glockjock Accessory and Maintenance Log, 2012 airbag model
6K views 50 replies 5 participants last post by  Glockjock
Note to self- Use this log to track any additions and/or maintenance to the Goldwing.
A 2012 ultra blue level 4 Goldwing with about 44K miles purchased from Len Ellis on June 15, 2019
Accessories included with purchase
$2600 Full Traxion suspension (front and rear)
$ 900 Windbender power windshield
$ 600 Hondaline CB
$ 600 J&M Bluetooth phone integration
$ 430 Honda OEM LED foglights with amber covers
$ 380 Mic-o-pegs
$ 300 Rivco trailer hitch
$ 299 OEM F6B tailpipes
$ 290 Honda OEM spoiler
$ 279 Transformer boards
$ 244 Centramatic balancers
$ 180 Sierra Electronics combo antenna
$ 160 HealTech Gear indicator behind left speaker cover
$ 155 Headlight modulator
$ 133 Kuryakyn passenger armrest LED lights
$ 120 Super Bright Multicolor LED lights with remote control
$ 100 EC 4 function spoiler light
$ 100 Honda passenger audio control
$ 99 Duck Foot side stand
$ 80 Six pin round trailer receptical with isolator
$ 75 chrome radiator grills
$ 68 OEM Chrome license plate frame
$ 61 Butler mug color matched by Wing Bling
$ 60 Show Chrome belly pan
$ 50 Battery Bug monitor
$ 35 DHS shifter linkage
$ 30 Battery voltage monitor light
$ 10 Battery charger pigtail
$ 10 GPS visor with dash light
$8448 Total Accessory Investment
All maintenance and recalls up to date
Rear suspension pump has been repaired to provide full range adjustment.
Cruise control has been adjusted to start without delay.
New battery, Michelin rear car tire, Bridgestone G709 front tire.
All the above was what I bought from Len
Installed new Windbender ST-11 top windshield, and farkle shelf in July because the former 15" shield was too tall.
Installed a Zumo 595 LM in July
Rear suspension actuator was low on fluid, so serviced and filled rear shock actuator and reservoir July 23. 2019 at 51, 645 miles. It now starts activating at 1. Will monitor for leakage.
Changed oil and filter, using Honda filter and Rotella 15W40 T-6 full synthetic on July 29, 2019 at 51, 993 miles.
See less See more
#2 ·
Note about Tailwind trailer tires
Installed two 4.80-12C tires at Modica Brothers in Jasper on Nov. 24, 2018. The mileage on the 2006 at that time was 312, 903. I sold that bike at just short of 320,000 miles so the tires had 7,000 miles on them.
The 2012 had 44,000 miles when I bought it and started pulling the Tailwind full-time January 6, the bike has 59,555 miles, or an additional 15,555 miles, so the tires right now have 22,555 miles. They look good,
Reactions: Pooch
#3 ·
Bought Battleax 130-70-18 front tire on-line and had Cowboy Honda install it on 12/10/2019 with mileage at 57, 626.
Also replaced all brake pads. New pads were $170.
#4 ·
Replaced rear tire on 1/07/2020 at 59, 679 miles with Bridgestone Drivegard runflat 195-55-16 car tire with 32 psig
#5 ·
Changed oil with Rotella T-6 5W40, and changed rear end oil at 59,776 miles on January 8.
#6 ·
Len Ellis changed the air filter, bled the brakes and clutch, and lubed a sticky reverse switch on Feb. 3, 2020 at 61,345 miles. FWIW, the air filter ready to be changed. It had about 24,000 miles.
#7 ·
Replaced left headlight low beam bult with Sylvania Basic H7 on 2/28/2019 at 63,096 miles. This bulb is the standard, lowest intensity bulb. Note to self for future reference- I was surprised to note the rated life, which is 270 hours. That equates to approximately 16,000 miles. Let's find out.
#8 ·
Changed oil and filter on March 28, 2020 at 65,065 miles with Shell Rotella 5W40 T-6 full synthetic oil.
#9 ·
Changed oil and filter (Shell Rotella 15W40 T6 with Honda filter)on June 8 right after returning from a Ride Around Texas. Mileage was 70,185. Oddly enough, also had to replace right low beam headlight bulb with another Sylvania Basic H7. The previous bulb only lasted 7000 miles. Wonder if I had touched the bulb in the process of installing it.
#10 ·
Len Ellis rebuilt the front forks, replaced the pulse generator for the crankshaft position indicator, and changed antifreeze at 71, 750 miles on Sept. 17. Also raised the forks 5 mm in the tubes. I’ll need to revisit that, because the bike is now very hard to get on the centerstand.
#11 ·
Dec. 1 changed oil and filter (T-6 15W40) at 77, 493 miles because I was on the road at 75,000 so stretched this change to 7.5K. I'll change again at 85K, then get back to changing at roughly 5K intervals.
#12 ·
March 30 at 79577 miles installed new rear tire, another Bridgestone Driveguard RF at 30 psig this time. I also managed to get the rear Centramatics back in place. Just noticed that the previous tire was installed at 59, 679 miles on Jan 7, 2020. This is 19, 898 miles and was just at the wear bars.
#13 ·
Replaced right low beam headlight bulb August 8 2021 at 85,730 miles. I installed another Sylvania Basic H7. I made sure to clean the bulb with alcohol and not touch it. I see the bulb was installed at 70,185 on June 15, 2020. It lasted 15,545 miles and 14 months. The mileage is almost exactly what the bulb is rated for. The left bulb is still going good at over 22,000 miles.
#14 ·
Changed oil (Rotella T-6 15W-40), Honda filter, and final drive fluid (Valvoline 80W.90) at 86,542 on August 21. The Goldwing will be seeing Len Ellis on 8/24 for a conjugal visit where Len will replace the controller for the circus lights, change spark plugs, inspect/replace brake pads, and install a mounted Bridgestone Battleax on the front and a mounted Pirelli P-1 on the rear. Getting ready for Ohio/Beartooth/Rockies Gold ride. I'm carrying the already mounted tires and wheels in the Tailwind.
#15 ·
Went to Len Ellis' in Helotes on 8/24. Bike had 86,900 miles on it when we rolled it into the garage.
Brake pad inspection showed the pads were not ready to be changed. The brake pads and front tire were all last replaced on 12/10/2019 at 57,626 so they had 29,274 miles on them.
I had a new set of plugs that I'd bought just because. Len reminded me the bike had irridium plugs that should be good for at least 100,000 miles so didn't change plugs yet.
Circus lights working fine now. It was merely a fuse, and Len could find no reason why it had blown. The circus lightas are pretty!
I decided not to change the rear tire yet as it has only 7300 miles on it so it should be good for at least 10,000 more miles.
Len installed the mounted Battleax front tire. The tire it replaced, another Battleax BT-45, had 29,274 miles on it. It still has life left in it, but not enough for the upcoming 6000 mile ride.
388744
388745
It is hard to believe this tire has 29,274 miles on it. If I were just riding local I'd have left it alone for a while.
Reactions: Pooch
#16 ·
Friday Sept 3 at 87,500 miles replaced tires on Tailwind, and put new battery in Tailwind. I no longer keep the Tailwind attached 24/7 but 27,000 miles ago on the bike the Tailwind tires had 22, 555 miles on them. I'm estimating the Tailwind tires had at least 30,000 miles on them. I bought new tires only because I'm leaving on 6000 to 7000 mile trip in a fewq days.
Just for information and in case the Tailwind Community asks, the battery price has doubled to $40 from the traditional $20 price of the Tailwind battery.
#17 ·
Changed oil and filter (Shell Rotella T-6 15W-40 and Honda filter) November 2 at 93,845 miles. Last change was August 21 at 86,542 miles so this was 7,303 miles on this oil. Next change will be at 100,000 miles.
#18 ·
November 16. 2021 Len and Carmine serviced bike again at 94,600 miles.
Replaced the irridium plugs which had about 75,000 miles on them with standard BKR-6E11 as I had bought the wrong plugs. The irridium plugs still looked good even at that mileage.
Rebuilt the Traxxion front forks again. The prior fork rebuild was at 71,750 miles so the forks had 22,850 miles on them. One of the wear bushings was fairly well worn, so I will make it a point to rebuild every 20 to 25K miles.
Replaced the air cleaner, which had been installed on Feb. 17 2020 at 61,345 miles so it had 33,255 miles on it. It was ready to be replaced, but not too bad.
Len spent a lot of time diagnosing and repairing a failed section in the "circus lights". The lights are beautiful. I'm a convert.
Reactions: schnits
#19 ·
Glen, I saw you were taking the Blue Lady to your local Honda service provider in Helotes. You need to up your game and get the correct iridium plugs for your next trek to H-town.
Rick
Reactions: Glockjock
#20 ·
Installed new Yuasa GYZ20L battery at Cowboy Powersports on 3/15/22 ay 98,700 miles. Battery was $182.49 plus tax, but had to have it now for the old battery died.
Reactions: Hondahawk
#21 ·
Changed rear tire at 100,239 miles. Put on a 195/55/16 Pirilli run-flat this time. The previous tire, a Bridgestone Driveguard, was installed March 30 of 2021 at 79,577 so it had 20, 662 miles on it. It was ready to be changed.
#22 ·
Burned out the left headlight bulb at 100,100 miles. If was OK in the garage, but when I pulled up behind a pickup a little later in town I saw that it was out. I replaced both while I was at it.
Left bulb was installed February 28, 2019 at 63,096. It lasted 37,004 miles.
Right bult was installed August 8, 2021 at 85,730 It gad 14,370 miles on it and was still looking fine. Replaced as precaution.
#23 ·
Changed oil (Rotella T-6 15W40) and Honda filter June 3 at 103,735 miles,
#24 · (Edited)
Installed a new Pirilli 195/55/16 runflat rear tire at 104,515 miles. The previous tire was installed at 100,239 on April 11 so had only 4,276 miles on it so it was still in great shape, but that wheel had a rubber valve stem. I want the metal t-stems so I swapped to a new wheel that had the correct valve stem. I'll have a t-stem put in this wheel and re-install it when I wear out the new Pirilli.
#25 ·
Len Ellis performed a complete brake job, installing new pads front and rear, and bleeding the brakes and clutch on 6/29/2022 at 104,850 miles.
Reactions: Bullet Bob
#26 ·
Changed oil, filter, and final drive oil after return from Northwestern Swing on August 8 at 113,107 miles. This oil change had 9,372 miles on it but with T-6 I ain't skeered. The drained oil still looked normal.
#27 · (Edited)
Left headlight low beam burned out while in Ohio on Sept. 4 (HondaHawk saw it when it happened) at about 116,000 miles. I see that I had replaced both bulbs at 100,100 miles on April 19. This left bulb lasted about 4.5 months and 16,000 miles.
