1 - 12 of 12 Posts
Love the new DCT tour and impressed with braking capabilities however at 23000 miles I replaced the pads and was disappointed in cost for replacement. I realized I was almost exclusively using the brakes for slowing down and stopping. Consequently the pads didn't last as long as I had hoped. I now conscientiously try to downshift when approaching intersections or approaching other stops. The downshifts are smooth and I am not overly aggressive on the downshifts. I am hopeful with this minor riding adjustment in how I slow down that the brake pads will last considerably longer. Chalk this up to operator error - nothing wrong with the brakes. They're great!
She is not a cheap date.
Love the new DCT tour and impressed with braking capabilities however at 23000 miles I replaced the pads and was disappointed in cost for replacement. I realized I was almost exclusively using the brakes for slowing down and stopping. Consequently the pads didn't last as long as I had hoped. I now conscientiously try to downshift when approaching intersections or approaching other stops. The downshifts are smooth and I am not overly aggressive on the downshifts. I am hopeful with this minor t adjustment in how I slow down the brake pads will last considerably longer. Chalk this up to operator error - nothing wrong with the brakes.
How far were they worn down?
I would imagine the inner pads were worn down more than the outers?:smile2:
All pads were worn down to replacement but inners were worn a bit more as I remember. It was a couple months ago. Sorry. The point I was making was that I was relying almost entirely on great brakes to do all the work because DCT is so easy to ride. The brake pads aren't cheap - now using downshifting when possible.
I remember a quote from 3 time world champion race driver Jackie Stewart. "Brake pads are a lot less expensive than transmissions."
Discussion Starter #9
I'll use my brakes to save wear and tear on the drive train and engine.
Surprises me you would say that - prior to the DCT, when you were approaching a stop sign did you hold in the clutch lever, downshifting but never engaging the clutch (only using your brakes to stop)? Based on the preceding comments posted I am guessing that your brakes pads on previous model didn't last very long. Best way to save all wear and tear is to just park the bike and admire from 3-5 feet away. This is the first time I have had someone suggest not to downshift a motorcycle in the pursuit of slowing down. Hmmm...
Yes. Close throttle, apply brakes, when rpm drops pull in clutch lever and down shift all gears while rolling to a stop. I use engine braking going down hill or as needed when entering a curve.
1 - 12 of 12 Posts
