1 - 20 of 78 Posts
Date................Mileage............Description
06/28/07..............0................Date of Purchase
............................................CB and Power plug installed
............................................3-yr Maintenance Contract
07/06/07...........450...............Bushtec Hitch/Isolator harness
............................................Fuse Block
............................................Kuryakyn Highway Pegs
............................................Colormatched Fender Extension
............................................Colormatched Scuff Covers
............................................Garmin 2720 w/interface
............................................Tulsa Mirror Air Deflectors
07/09/07.........1,074..............LOF
07/27/07.........4,100..............4K Service
08/23/07.........7,725..............8K Service
09/15/07...............................Tulsa Windshield/Belly Pan
09/18/07........10,963..............12K Service
10/23/07........15,897..............16K Service
12/10/07................................MBL Risers
.............................................Fixed Trunk scuffing (added fuel line inside gasket)
12/18/07................................Colormatched Escapade Elite Trailer
02/10/07........19,932..............20K Service
04/01/08................................Show Chrome Driving Lights
04/17/08................................Tunnel Fillers/Passenger Backrest Gap Filler
04/30/08................................Show Chrome Driver Backrest
05/15/08........21,500...............Replace Rear Tire (D250)
05/22/08........24,165...............24K Service
.............................................Replace Front Tire (D250)
06/25/08........28,041..............28K Service
Discussion Starter #2
Re: Greytful's Metallic Red 2008 Premium Audio
Just had the clip for the left saddlebag break - replacement of clip and actuator rod is under Service Bulletin 15 (for non-ABS 08s with Serial numbers less than 2181.
23 July 08.............. 31,600 miles .......... 32 K service
No adjustments required for valve clearance.
Warranty repair of left saddlebag rod and clip done - works real slick now.
Everything else is good to go.
Ride safe and ride often!!
Discussion Starter #4
28 August 08 .......... 36,595 miles ..........36K service
Oil and Filter
Radiator Coolant
Brake/Clutch fluid
Shaft Oil
Air Cleaner
29 August 08 ............ 36,689 miles
Added Show Chrome Antenna Flagpoles
US Flag
POW/MIA Flag
02 October 08 ---------- 38,730 miles
Noticed a wobble (under acceleration only) the last time I rode and checked the torque of rear and front wheels, suspension, and axles with no discrepancies. I had checked the rear tire slowly, but this morning I spun it and watched the tread. I finally spotted a bulge on the left side of the tire, indicating some type of tread separation. Fortunately, I had a spare rim and tire on hand.
Tire Information: Dunlop D250 ---------- 17,230 miles ----------- 2/32 tread depth
Discussion Starter #7
08 October 08 --------- 40,717 miles --------- 40K service
Oil and filter
40K maintenance checks
Discussion Starter #8
12 January 2009 ---------- 43,976 miles ----------44K Service
Just another routine ho-hum service. :thumbup: Will probably need left front brake pads at the next scheduled maintenance (48K). The front tire will need to be replaced again at that time (will have 24K on it).
Lost one of the flagpole masts (and flag) on the highway when the set screw backed out. Had to order the entire pole and mount. :-( Will use a little loctite on the allen head set screws so they won't back out again!
Discussion Starter #9
Flagpole replaced
Purchased new flagpole w/flag and reinstalled. Put locktite on both allen head set screws. :thumbup:
Discussion Starter #10
Headlight
6 March 09 ----------- 44,834 miles
Right low beam headlight bulb burned out today - replaced both of them and saved the working one for a spare.
They sure don't give them away!!
Discussion Starter #11
New Flags
19 March 09 --------- 45,672 miles
Just received and installed new PGR and US flags from Time and Again Photos. They are silkier than the original cotton, and the seam stitching is better. Like Dave told me - abuse them for a while and let him know how they stand up.
Discussion Starter #12
48K service
4 April 09 ------------ 46762 mi
48K service performed a bit early. Replaced front D250 (22,597 miles) and had the left front brake pad set changed.
When I purchased the Wing I also bought a 3-year unlimited mileage maintenance contract for $900, covering all scheduled maintenance except brakes and tires. It was the best move for me, I have received $3,644.12 in service so far, with over 14 months to go!! :thumbup:
Oil and filter, coolant, brake and clutch fluid, and shaft oil changed.
Discussion Starter #13
Tail light bulb
20 Apr 09 -------------- 47,357 mi
Right tail light on trunk burned out. Replaced both bulbs while I had the light out.
Discussion Starter #14
Grip Puppies/Throttle Boss
10 May ------------- 48,539 miles
Added Grip Puppies and Kuryakyn Throttle Boss
Discussion Starter #15
11 Jun --------------- 52,332 miles ------------52K service
Oil and filter. Everything else OK.
Discussion Starter #16
10 Jul --------------- 56,908 miles ------------ 56K Service
Oil and filter, everything OK.
Added a beaded seat pad at Wing Ding in Tulsa. Looking into powdercoating wheels.
Discussion Starter #17
60K service
19 August ---------------- 61,174 miles--------------60K checkup
The tech noted that the brake switch on the handlebar was sticking. New switch was ordered and will be replaced under warranty. Everything else was OK.:thumbup:
Discussion Starter #18
Powdercoated Rims
24 August 09
:thumbup:Just picked up my newly polished and powdercoated rims from the tire installer. This should save a lot of time and effort that was required to keep up with the brake dust that eats into the rims (especially the rear). Will put them on as I wear out the current tires. I plan to buy front rotors so I'll have a fresh set of tires on rims to install as needed.
Discussion Starter #19
Brake Switch
27 Aug 09 ---------- 61,753 miles
Dealer replaced sticking front brake switch under warranty.
Discussion Starter #20
31 Aug 09---------- 62,080 miles ----------new tires
Couldn't wait - I had new D250s mounted on the powdercoated rims, added Dynabeads, and put them on today;). Went for a short test ride and the ride seems to be rock solid and smooth:thumbup:. Bringing OEM rims I took off to the powdercoater tomorrow.
1 - 20 of 78 Posts
