41 - 60 of 78 Posts
Discussion Starter #41
12 Oct 11 -------------- 112,678 miles
Brought in for 112K service. Both front fork seals blown:-(. Ordered all parts for fork rebuild (seals, bushings, etc.) and will bring back next week.
Discussion Starter #42
Fork rebuild
19 Oct 11 -------------- 113,310 miles
New fork seals, slider bushings and guide bushings installed.
Both sets of front brake pads replaced because of oil contamination.
Discussion Starter #43
Recall and Service
14 Dec 11 --------------- 116,289 miles
Replaced a broken driving light lens yesterday (2nd time on the right side!).
Routine 116K service at dealer. Had the brake recall taken care of - no problem.
21 Feb 12 --------------- 117,543 miles
Replaced left low beam headlight.
Discussion Starter #44
Early tire change
6 March 2012 ------------------ 118,137 miles
Put on a new set of E3s early to get ready to take the Experienced Rider Course. Tires had 16,505 on them, had a lot of tread left, but were cupped enough that it probably would affect low speed moves. I'll proobably go back to the D250s because they cup less and thereby aren't so noisy.
Discussion Starter #45
22 Mar 12 ---------------- 118,435
Installed new E3s front and rear.
10 Apr 12 ---------------- 120,806 miles
120 service performed. Only exception noted was more oil in the air cleaner than is usually found. Have not had to add oil between changes - will monitor and recheck at next air cleaner replacement.
Discussion Starter #46
New Battery and 124K Service
30 APR 12 -------------------- 122,235 miles
My Battery Bug was showing that the OEM battery was slowly going South. I replaced the battery with an Odyssey PC545, as I have had excellent service from this particular battery. I had one in my '88 Wing for 10 years, and it cranked just as strong when I sold the bike. The PC 545 in my wife's '94 SE was installed in May of 2004 and still cranks as fast as it did when new.
____________________________________________________
15 MAY 12 -------------------- 125,280 miles
124K service performed - no problems:thumbup:.
Discussion Starter #47
15 JUN 12 -------------------- 128,719 miles
128K service. Valve check done and everything still within specs. What a great motor!!:thumbup:
Discussion Starter #48
132K Service
4 SEP 12 --------------- 131,94 miles
Scheduled service (oil, filter, air filter, hydraulic fluid change) - no problems. Looking at left front and rear brake pads shortly.
Discussion Starter #49
Rear Brake Pads
15 Oct 12 ---------------- 135,587 miles
Put in second set of rear brake pads - 63K on this set. Full teardown and cleaning of caliper components.
Discussion Starter #50
Routine service
23OCT12 ------------ 136,216 miles136K service performed. Also changed spark plugs.
Discussion Starter #51
Brakes and Tires
27 FEB 13 ------------- 138,683 miles
Installed other set of rims with a fresh set of D250s. (19K on the E3s) Although they were still serviceable I installed both sets of front brake pads. We are planning a trip out West to tour and then participate in Run for the Wall and will be towing our Escapade. I didn't want any surprises.
Fred's website was a great asset, particularly when it came to taking the calipers apart to thoroughly clean them, which I hadn't done before. You can find a lot of info about many installs at http://www.pbase.com/fredharmon.
Discussion Starter #52
140/144K services
02 April 13 -------------- 140,867 miles
140K and 144K services done in preparation for our 12K bucket list trip to the West Coast . . . doing Run For The Wall to DC, Rolling Thunder, and then Americade in Lake George NY.
In addition to the oil and filter change, Charlotte Honda did the 144K services - air cleaner replacement, coolant flush, final drive fluid, and brake and clutch fluids. With the new tires and brakes I put on I think we're good to go.:thumbup:
Discussion Starter #53
Service in CA
13 May 2013 ------------------------- 147,956 miles
Oil/Oil filter, general checkover in Ontario, CA prior to RFTW. Got the bike a little hot at Dante's View in Death Valley, and local temp here is 104 degrees. Checked and replaced radiator cap and added coolant. Otherwise a routine service.
Discussion Starter #54
14 Jun 2013 --------------------- 153,494 miles
152K service performed and plugs changed.
When in CA broke all the tabs off rear half of front fender. Removed fender extension and used Gorilla tape to hold it on from LA to DC to VT to NY and return to NC (over 5,000 miles). Ordered new one.
Discussion Starter #55
13 SEP 13 ------------------ 156,322 miles
156K service performed. No issues:thumbup:
Discussion Starter #56
18 Sep 13 -------------------- 156,442 miles
New D250s installed. Mileage 17,759 - over 14K 2 up w/trailer
Discussion Starter #57
05 Dec 2013 ---------------------- 159,478 miles
160K service to include oil/filter change, plugs, and valve check. No adjustment required at this time but probably in the near future. Four intake valves were measured at .127, with the other two at .152. All exhaust valves were at .152.
Discussion Starter #58
first warranty repair
25 Feb 2014 ------------------ 159,945
Bike in for short in running lights. Replaced left turn signal/radio combo switch on handlebar and the bank angle sensor. $653 charged to warranty - retail price would have been over $850.
Discussion Starter #59
20 May 2014 ------------------- 163,167
164K service done early (everything OK) - leaving Friday for Rolling Thunder and then to Americade.
Discussion Starter #60
09 Sep 14 ---------------------- 168,583 miles
168K check - routine maintenance
Replaced tires - front is Bridgestone, rear is another D250. Only a little over 12K on the set - lotsa riding in the twisties.
41 - 60 of 78 Posts
