61 - 78 of 78 Posts
Discussion Starter #61
05 NOV 14 -------------- 172,338 miles
172 K service completed - good to go!!
Discussion Starter #62
21 May 15 ------------ 176,660 miles
Routine service oil, filter, plugs
Added Kuryakyn Lightning Valve cover set as the cylinder head finish was worn off - first farkle added for the sake of chrome . . .
Discussion Starter #63
180K service
08 Jul 15 ------------------ 180,107 miles
180K service (air filter/hydraulic fluids/oil and filter. Replaced rear tire - down to the wear bars in less than 12K.
Discussion Starter #64
184K service, rebuild front suspension/steering head and brakes
10 Oct 15 ------------ 184,214 miles
Routine oil and filter change.
17 Oct 15 ------------ 184,381 miles
Replaced upper and lower for bushings and oil seals, installed Progressive Suspension Monotubes, All Balls steering head bearings, and both sets of front brake pads
Discussion Starter #65
5 FEB 16 --------------186,581 miles
Factory recall service done.
Replaced rear brake pads
Discussion Starter #66 (Edited)
18 Feb --------------- 186,597 miles
Replaced front tire. Pleased with 18K from the Bridgestone.
Replaced switch for driving lights.
Discussion Starter #67
192K Service
19 May 2016 ------------- 192,392 miles
At this checkup all the scheduled maintenance services are performed - oil and filter change, air filter, spark plugs, brake and clutch fluid flush, final drive service, coolant flush, and valve check.
All is well.
Discussion Starter #68
196,000 service
23Jun16 -------------- 196,723 miles
Routine 196K service with no exceptions.
Discussion Starter #69 (Edited)
14Aug16 ------------- 198,490 miles
Cleaned and refilled the rear shock actuator - it wasn't working until it read 10. Quite a noticeable difference after the service.
Rode 200+ miles yesterday, and 3 miles from my home a front wheel bearing failed. Have another wheel and tire set so I just replaced the front assembly. Glad it happened so close to the barn!
Discussion Starter #70
06 Feb 17 -------------- 202,392 miles
Oil and Filter change. Went to Rotella T6 5-30 Full Synthetic.
Discussion Starter #71
07 Aug 17 --------------- 212,000 miles
Oil and filter change. Installed new rear Bridgestone.
Discussion Starter #72
28 May 18 --------------- 221,622 miles
Discussion Starter #73 (Edited)
27 Aug 18 ------------ 229,500
Vibration in mirrors at speed last time I rode. The final drive was making noise when run in gear on centerstand. Replced final drive and driveshaft - one of the bearings in the final drive was noisy, and the u-joint in the driveshaft was toast! Flushed hydraulics, changed oil and filter
Discussion Starter #74
Tire and Brakes
23 February 2019 -------------- 231,644 miles
Replaced front Bridgestone. Cleaned front calipers and replaced front brake pads. Also replaced rubber seal at end of pad pins.
Discussion Starter #75
12 Sep 19 -------------- 242,500 miles
Oil and Filter change. Almost time for new rear tire.
Discussion Starter #76
Avon rear tire
27 Oct 19 --------- 244,034 miles
Installed Avon Cobra rear tire. Curious how the mileage will be vs the E4s and Stones.. .
Discussion Starter #77
01 Apr 20 -------------- 246,320 miles
On trip to Florida last month the F1 light came on and stayed on; however, the Wing ran smoothly. The code given with the kickstand down and in neutral was for the right knock sensor. Replaced the spark plugs (which were long overdue) and tried to fool the system by using Techron and premium fuel. Returned home and replaced sensor and all is well - thankful it wasn't the ECU!!!
Discussion Starter #78
20 May 20 ------------------ 247,353
New air filter - quite dirty - over 50K since last changed. MPG was still averaging 41.
61 - 78 of 78 Posts
