1 - 3 of 3 Posts
Hi Everyone,
I am in the process of figuring out which LED lights to buy and where to put them. It seems like I need some of this kind and some of another kind. Can I mix LED lights up like that and have tem work OK?
I would like to have some "MIni-skinnys" as running lights going down the side of my trike. Can I add some glo-wire to that system?
Than I want some ground effects lights underneath. Can I mix strip lights with pods?
Mix and match with no problem. Just remember that circuits that require a specific load to work properly (turn signals) will need some add on loads if the LEDs are used alone.
the type of lights wont matter, mix and match, just make sure all lights have there own 12v and ground as in all in parralel, as long as you dont exceed the fuse rating for the lighting curcuit, leds should be ok as they are low current. if you add to much you will have to put in a relay to get more power for extra lights
1 - 3 of 3 Posts
