Tom, If you take ah good close look at th 2 little plungers ( i think 1 is th brake lite & 1 is th cruise cancel) under th front brake lever you might see somethin clogged in em preventing them from movin in & out when th lever is moved. WD-40 & ah toothpick will usually clean out th debris & git th plungers freed up movin normally agin. This happened ta me on th road last year, after i cleaned th junk out from around th plungers, th brake light started ta work normally & i've had no more problems with it after that. :mrgreen:
