Hmm.... That's not entirely true. The balls of the bearing run on a race where the radius is matched to the balls' radius so it's not a single point loading the way you describe.You can imagine the point loading of a round ball bearing pressed against the race compared to the area of a roller in a set of tapered roller bearings. The image can be illustrated with an 8 lb rolling pin laying on a bowling alley compared to an 8 lb bowling ball.
PM sent.Also, tracking bearing notching complaints on here would indicate a much more common occurrence with roller bearings than with the OEM ball type. Probably because it is often used as a fix for the famous deceleration wobble and gets overtightened to do it. I still have the first thing that I bought to add to my first wing. It's a set of All Balls tapered bearings for the wing. They are still in the blister pack. I never used them and I have had 3 more wings since then. I'm never going to use them so if anyone still believes that they are a better choice, they can pm me an offer because I just came across them again the other day.
Richard
Not to beat you up, but in addition to what J.W said, the statement in bold is misleading. Ball bearings are not used because they have a lighter feel. If you compare datasheets for any comparable ball bearings vs roller bearings, the COF on both of them is virtually identical. If you don't have a light feel with roller bearings, then they were either installed wrong or they are defective. And this is exactly what owners are doing when they follow the All Balls recommendations for torque. This is probably an even bigger reason why so many of them fail than the quality of the bearings. Bearings of any kind are not designed to be used as dampers. Both types are intended to eliminate, or at least minimize rotational friction, not increase it.OEM caged ball bearings when adjusted correctly have wonderfully light steering but if they get even slightly out of adjustment the balls can hammer small dents in the outer race that the balls press against. They are also somewhat harder to set up and torque properly when replaced. The answer for many DIY owners is to install aftermarket tapered roller bearings that are less fussy to set up and resist denting because the point loading is less. The proper term is brinelling instead of denting.
Yes, there's no reason not to since its half way pulled apart. Just rotate the yolks gently and feel for notchiness in the bearings. Don't confuse it with a catch from any cables or hoses you may still have attached.Question here:
My bike is now in the shop for a bushing leak in my front forks... So I'm replacing the bushing as well as the front springs... Would these "Ball bearings" be also checked at the same time???
I need an answer very fast before bike is put back together, and I still have bad bearings.... I would want them replaced before front end has been put back on the bike..
Thank you
Ronnie
A notch in the bearings is very noticeable during riding and when you move the handlebars. You don't have to be a mechanic or even a highly experienced rider to sense it. If you have never noticed anything, I would not worry about it. The center line wandering that Fred mentioned is a common side effect, that that is not as easily discerned as a bearing problem unless you are experienced.Question here:
Thank you
Ronnie
It is called brinelling. Google it for pix.I have a question? What does it mean when the OEM steering head bearings developed a notch in it.
