1 - 3 of 3 Posts
Trying to use a Kennedy 5 pin DIN converter (part # 95088) to listen through my walkman headphones on my '01 1800. All external speaker functions work OK for radio, CD and CB. I can't tell if the standard Wing headphone connecters are working properly since the walkman headphones (via the converter plug) are the only ones I have at present. In my testing,... the mute is always off and the headphones logo appears properly on the audio display. Any suggestions are greatly appreciated.
Thanks. :roll:
Test the headphones by plugging them into a walkman.
If they are ok, try plugging them into the kennedy adapter and in the passenger position. If no sound is present, then the adapter is bad.
Please return it for a refund or replacement..
Thanks for prompt reply Jon. I have already tried what you suggested, I will next try to find someone else's conventional headset to make sure my audio system is working.
1 - 3 of 3 Posts
