This one gave me fits for a couple of days, so I thought I’d pass it along on the off chance someone else runs into it and maybe it’ll save them from some frustration.
I started connecting electrically heated clothing to motorcycles thirty or more years ago and have never run into this …………………until now:
I saddled up, plugged in and headed to my customary fuel stop before my ride, the routine is usually, plug in my gear, start the bike, pull out of the garage, close the door and switch on the gear.
But when I got off the bike and unplugged the heated gear, I didn’t turn it off, after fueling I plugged in and the bike would not turn on, so I turned off the fob, turned it back on and it started.
Then while riding the dash light for no key present came on, pulled over and fussed around for a bit, unplugged my heated gear and everything was as it should be.
I upon my return home I started to go down the list of things to check, battery, connections, measured to make sure the heated gear itself had no internal issues, I have more than one set of gear so I swapped out components one at a time in an attempt to narrow down what the problem was and everything was working fine.
So, I walked away ……………………….
After a day I took a fresh look and did some more diagnostic searching ………………………...nothing.
Lightbulb!
Every time I checked something my key fob was in my pants pocket or near enough so that its signal was detectable to the bike but some distance away from the heated gear itself.
My keys are always in my right jacket pocket (right against where the heated gear is) so I took the key and placed it against the heated gear and nothing.
Move the key away from the heated gear and everything works correctly.
The only thing I can surmise is that there is just enough magnetic field emitted from the heated gear that it prevents the signal from communicating with the bike’s receiver.
One of those learning experiences, new technology sometimes requires some getting used to.
Ride Safe One and All
Lightbulb!
