Under the seat. The pig tail sticks up between the seat and the "tank", and if I feel like it during the summer, I.put it under the seat.
Sent from my SM-N920T using Tapatalk
From the battery, along side the left side cover and out up front.
Keep in mind that the blank "no parking brake" cover is actually the access panel to adjust the reverse cable play for the manual transmission model. Remove the panel and one can tighten up the reverse actuator cable without having to remove the top shelter. My reverse cable needed tightening and I was happy to easily do it there as opposed to having to remove lots of plastic and take off the top shelter. :wink2:The controller is "dual lock" stuck to the blank "no parking brake" cover. The wire is coming out from under the shelter and up to the controller, knobs up. I did have to extend the wires a bit to make it all reach.
