Right now Im taking a long hard look at heated liners (pants and jacket), and am pretty-well decided on either First Gear or Warm & Safe Gen 3 (the same product). However, the next decision I have to make is on controllers.
Is there any HUGE advantage of the dual controller over the single controller? I understand that if I have the single unit, the heat in both jacket and pants (or gloves) will be the same. Also, can all three (or four) items..., jacket, pants, gloves, socks, espresso machine, etc., be plugged into a single controller?
Is there any advantage over the mounted and semi-mounted controller?
For the driver, where do you have the controller(s) mounted, and where have you routed the connector plug-in?
Same for the passenger..., where's the best place to install the controller(s), and where have you routed the connector plug-in?
Thanks for suggestions, advice, and especially pictures, about installations.
