My 03 Wing has 99,000 miles on it, I lost my altenator at 89,000 n if I had known my water pump was going to fail then I would have replaced it then.n I kept finding coolant and could not find any leaks anywhereon any hose connection I could see so I pulled the tank and the waterpump and it was what was leaking, the o ring that seals the crancase was bad and leaking oil also. Ordered the waterpump from directline parts last thursday which I recieved last night. Along with a coolant tank. I pulled the tank to clean an found what looks like a crack on the bottom. I decided to change all the rest of the fluids while its up in the air, and change out the rubber since the Kuhmo was about shot and the BT was cupped bad on the front. I also changed out the rear Disk since it was worn out. I have a complete rear end from a buddy who triked out his Wing. I just got finished vacuming out the cooling system It held a vac for 30 Min so I think its good n tight let it suck the new honda fluid in and fired it up let it heat up, new tires are on rims dynabeads are in tires are mounted all bolts are torqued, pads looked good n although I bought new pads there wasnt much wear compaired to the new pads. Jus need to put the tupperware back on will finish it up in morn All in all it was a good day n bike should be good for another 99,000
Ron
Ron
