I recently installed the Kury floorboards with the heel-toe shifter. At first everything was fine and I was really enjoying the new setup. Then all of a sudden (within about 30 miles or so) I began to have difficulty downshifting. Upshifting 1 - 5 is perfect but sometimes I can't get it to go back down beyond third gear. :? I can't really see how the shifter itself could be causing this, but thought I would toss it out to you guys for comment. Tomorrow I plan to remove it just to see if the problem dissappears. If anyone has had a similar experience or an idea as to what might be happening I would love to hear it. Thanks.
I had the same set up on my 2006 Goldwing. After qbout 3 days (100 miles) I removed the flloor boards and shifter because I never really felt comfortable with it. Although I never had any consistant issues, there where times when shifting it was not going into the next gear. I never figured out if it was me or the setup. I have always felt most in control when being able to choose wheter I wanted to use the toe or heel to shift in a hurry, because you can only use the heel to shift up, and I was not always catching the next gear, I switched back to the stock setup..
Anyway.. Good Luck.... have a Safe and Happy New Year
One of the problems that can arise is the heel part of the shifter is a little too far to the rear and down. It can be difficult getting the full push with your boot heel causing the gear to go into a false neutral. This can be caused because of high top tight fitting boot or your ankle joint not flexing far enough to let the shifter go all the way down. A remedy to this is to make an adapter that will raise the heel shifter about a 1/2" higher and about 3/8" forward to a more comfortable position. It should not be too far forward or it will hit the floorboard when it hinges up. Will post pics soon.
Here's a few pics of an adapter I just made up. It's like riding a different bike. I don't have to stretch to heel shift now. Scuse the dirty bike, I just came in from the rain. Can't complain it could have been snow.
I'm surprise to read anything bad about the 1800 Kury boards. I installed them on my 1800 trike about 1 month ago, and with mild weather was able to test ride them about 3 times on fairly good distances. The shifting was completely smooth, up and down, and I would have to say as good as the Markland lo-boys that are on my 1500. I did just remove M C boards from 1800, but only because I wanted all my boards, and grips to be Kury's. ( There was nothing wrong with the m c boards either, sorry already sold) Stick405 says it might be a boot, or shoe size, or just a matter of getting use to them, and I total agree with all that. Also you don't need to "beat" on the toe/ heel shifter, but a easy "tap" is all you should need to do, and is certainly easier than the stock shifter. For some 20 years on older wings, I never had boards, with shifters, until a friend finally talked me into them( the 1500 was the first one), but now, I would never be without them, no matter the make.
Ride safe.
Legend in His Own Mind
Take the shifter off and see if the bike shifts normally using just the shift peg. If it does you have a H/T shifter problem. If it doesn't you could have a bent shifter fork according to some previous posts. I dislike boards for the interference or clearance reasons so I don't run 'em. I do run a Rattlebars kickshifter H/T with standard pegs works great and has never given me a problem of any kind.
