1 - 8 of 8 Posts
All the little thing where checked. The local Honda Mechanic said the Key is not recognised by the Bike - Both Keys.
The Safety Red Light - Far Left on Taco......always blinks when Bike is off.
The light should go out when starting the Bike.
Please Help.........have not got a clue
does your wing have hiss fitted? try disconecting the battery then try the keys when you reconect battery it may sort it out.
Did you add a chrome garnish around the key area? This has caused problems on those with security systems before.
this only effects models with hiss fitted which i think were only sold in europe & will cause the wing not to start.
If your bike is a 2006 then the dealer should be fixing that problem under warranty. Why didn't they when you had there?
Hello this is a bike with HISS !!!!! they Honda should be abke to correct this or order a new lockset with keys..chuck...............PS..... DO NOT PUT A CHROME THINGY around the key switch area!!!!!!! It screws them up!!!!!!!!!!!!!11
Okay it does not start.
What does work when you put the key in and turn it - any lights come on?
Check that the "reverse" button is not in.
The light on the left is the "immobilser" lamp and will flash until you turn the key.
1 - 8 of 8 Posts
