1 - 9 of 9 Posts
Installed a Honda cb into my new 2013 today. The cb was out of my old '08 so I had to use one of the adaptor cords. Everything was pretty straight forward and as far as I know the plugs on the radio only fit back one way and the cb plugs into the top center of the radio. I did forget and and turn it on for a few seconds before the ground was connected but the antenna was plugged in. All I get on the dash is "CB ERROR".
Did is you connect the power cable
if so try some contact cleaner in the old CB cable 13 pin plug
Tried to clean out the old 13 pin. Didn't have any contact cleaner but used a silicone spray. The ground strap is hooked up. Wondering what else might give this message? I did have some trouble disconnecting the 13 pin from the old bike. wonder if I damaged one of the 13 wires.
Had the same thing happen to me, but it cleared on it's own (don't know why). However, when I was searching for solutions, a rider on another forum said to disconnect the battery's ground cable, wait 10 minutes, then reconnect it. Easy to try it. Hope it works for you.
Steve
Could be a bad adaptor call Nicki in our office for a replacement
Hey Pedo do you work on OEM cb's or know anybody that does? It is a Clarion made in 2006.
User on this board LarryM if I remember correctly repairs and updates CBs
Discussion Starter · #9 ·
"10-4 good buddy" (How'd you like the way I worked cb language into a cb related post). I am sending mine to Larry M today. Just noticed you are over at the villiages. You ride with the Prowlers any?
1 - 9 of 9 Posts
