First of all......many many thanks to the folks at Electrical Connection for the info they have provided so far...great folks!
Unfortunately for them and you, I am not the most mechanically inclined (Electrical Engineer).
I am considering adding the Electrical Connection High Output Cowl Lights Model 1215 to my 2006 non-airbag GL1800.
Have not ordered them yet, but Casey at EC sent me the install sheets as PDF.
I have removed to cowls to clean and "take a look" ...but between the quality of the photos and such, do not feel I yet have the needed info to install. I hesitate to bug the folks at EC anymore until I've actually spent some coin with them...so I turn to the fount of all knowledge GL1800s.
To wit: The text talks about removing with side cutters the "dead plate"... I presume that this refers to the couple inch diameter convex piece on each side where the lights will go?
I'm uncertain, because the next step talks about melting some holes through the gussets, but the photo shows this being done on a cowl where what I think are the "dead plates" are still in place.....
As for exactly where to melt the holes, I am confused about the entire set of steps of measuring to the center from front to back of gusset, then marking a hole back 3/16" of an inch from the edge of the plastic, creating an "X" where the hole should be melted.....Is my attached sketch right? Am I correct about removing the couple inch convex (from the front) pieces?
Thanks...am a big believer in "read 3 times, measure twice, cut once".
Any words of wisdom from those that have done this in past will be appreciated...
