Where is a convenient spot on my 2005 Wing to tap into the electrical wiring for my pull-behind trailer?
Trailer has the following wiring:
1 wire for ‘left turn’ signal
1 wire for ‘right turn’ signal
1 wire for ‘brake’ lights (both)
1 wire for ‘running’ lights (for tail lights & side marker lights)
1 wire for ‘ground’
I am using the 5-pin Kuryakyn Trailer Hitch Receptacle & here is the link to see it: http://www.directlineparts.com/product.asp?pid=6167&str=4
Some additional notes:
1 - All lights on the trailer are low-current solid state LED’s (including the side marker lights)
2 – Don’t want to buy an interconnect harness
3 - Will ‘tap’ into the Wing wiring to give me the above listed trailer wiring
5 - Will not put a 'dome light' in the trailer
THANKS, in advance, for your help!
1 wire for ‘ground’
