The turn signals will NOT cancel by just turning the steering from stop-to-stop sitting in the garage.No, it's minus negative two below right now.
I'm just closing things up after a bunch of work and I am checking the turn signals out before I put the shelter back on.
So....I gotta go ride it outside to find if it cancels huh?
That is some global warming.. It is 1 here in Cottage Grove!!!!!!btw - you need to move North..........it's 75 and sunny here in White Bear Lake. :thumbup:
Correct. There is a speedometer input to the turn signal cancel unit. It is designed this way so if you are sitting at a stop light and move the handlebars, you turn signals won't shut off accidentally. You have to be moving before they will cancel.The turn signals will NOT cancel by just turning the steering from stop-to-stop sitting in the garage.
