As recently posted, I had a Pirelli P1 RF go flat. Luckily I was just coming in off of a state highway into a gas station when the TPMS started to show I was losing pressure. It did not act like a run flat when it was down. When the tire was changed they showed me the old tire. It appears to have dry rotted around the bead. You could flake off rubber all the way around. It was hot day 95 degrees, we were loaded for vacation 40lbs on the pak it rack, and a total of 80lbs divided among the 2 saddle bags and the trunk. I have been running 28lbs in the tire. The second operator is 150lbs with gear on. I am 230 with gear. The tire's date code says it was made the 16th week of 2017.
The question is did I overload the tire with to little pressure on a hot day or was it a bad tire? Any help or wisdom from the crowd would be appreciated. And may help someone else in the future.
