1 - 16 of 16 Posts
We need to replace the front tire on our trike... like yesterday... and I don't want to spend the time it'll take me to read thru all the "tire threads" (no pun intended) to figure out which one I need to get installed... and what direction to install in... yada yada yada...
So I need a short list of this is what I have... and how many miles... and I'd buy it again...
Thank You Kindly!
tire
MPA, Michelin Pilot Activ, mounted in reverse direction.
MPA - almost 15,000 miles mounted forward.Would buy again.
MPA - almost 17,000 miles mounted reverse
Metsler Lazertech - 8,000 miles and counting - like it better than MPA
Good luck on pick. Don't think you can go wrong with either.
MPA Mounted in Reverse 21K and counting 41 # air
Mounted in either direction is giving fantastic mileage results. Capt Denny has in excess of 27 on his I think.
Squating Member
if HDL doesn;t have what you need, call
http://ronayers.com/
they can get it to you fast....good prices too.
MPA mounted in reverse rotation...........12K and still going strong
Two MPA's both cupped gonna try something different might be a Bridgestone BT45
MPA, mounted reverse, 36-41, very slight cupping and going strong at 17,000.
MPA changed to Metzler Lazertec at 25K. Lazertec has 8K. I like both. Will buy either next time....both reverse rotation @ 41#. No cupping.
Squating Member
Michelin Pilot Activ (MPA) MotrocycleSuperstore.com About $105 + free shipping A lot of riders on this board went this way!!!
PS Mount in either direction, but I think even Michelin says to mount it in reverse direction.
MotorcycleSuperstore.com now has the MPA 130-70/18 for the front of your trike for $106.99 plus free shipping. 1 to 3 days delivery anywhere in the contiguous 48 states. That deal is hard to beat!!!
Discussion Starter · #15 ·
The new tire is on order (from Motorcycle Super Store) and will be here Friday. Thanks Everybody!
Hey Bambi, Now don't forget that after the MPA is installed on your trike you will very likely experience a "buzz" with the tire not only in feel but sound. This "buzz" should disapate in about 500 to 1000 miles. I have just over 2000 miles on my MPA and still feel a very, very slight "buzz" but the "buzz sound" is gone. It is still a great tire, so enjoy the many miles of service you will get from it.
1 - 16 of 16 Posts
