1 - 17 of 17 Posts
I have no fog lights I looked on my fuse box and they dont have a fuse number for it any idea's
that would cause the lights not to work becacse the light on switch still works?:shrug:
I just checked all my fuses again and nothing took the pocket out i caint find anything wrong
John.What brand of running/fog lights are you using?
Hondaline?
Show chrome/BBP?.
EC?.
Can you run them all the time with Hi beams on?.
Just had to replace the OEM switch for my Hondaline fog lamps. The backlighting will still work even when the switch burns out. If your switch still lights up, you have power to the switch. $40 for a new switch plug 15 minutes of your time and you'll have working lights again.
  1. Pull the switch apart
  2. Clean the contact
  3. Bend the contact back into original shape
  4. Watch out of the contact spring (See multiple threads about it flying across the garage into neverland.)
  5. Put it back together
  6. Try the lights.
This worked for me. Cost = $0. Time = 25 mins
Not a bad investment of your troubleshooting time.
Bob
On my Big Bike fog lights I had an interment problem with them and it turned out to be the wiring harness that has the relay on it. Big Bike doesn't sell that part so I ended up getting one from Electrical Connections. After the part arrived I figured out that one of the connectors inside the plug had never been "seated" properly.
Discussion Starter · #14 ·
They are big bike parts and they are on with the low beams it says in the instrctions they run just like oem I had the dealer install when new bike has 4200k its an 08
Isn't there a in line fuse on the BB harness?
1 - 17 of 17 Posts
