1 - 4 of 4 Posts
Need help guys I washed my 05 wing today with a garden hose just like always wiped everything down got on to go for a ride and looked down and the spedo had quit. I went about 2 miles and the F1 light came on so I rode it back and put it in the garage it has 19,000 miles any ideas? Please!
Thanks Oilman
I've heard of this before, you got some water in where it shouldn't be...my bet is the problem goes away when it has time to dry. :)
No speedometer.....
I had that occur once, same conditions, immediately after its bath. I have a yellow box sitting in front of the right faring pocket and it ended up getting water on the plug. My first thought was a wire came loose, but only found water. I remembered that I had some die-electric grease and put a bunch in the plug (after it air dried) and I never had that problem again. The speed sensor plug is just under the right chrome engine cover and side of top shelter. It could be that this plug got a bit soaked. It is fairly easy to check out the pulses from that plug. If you have a yellow box, you can use its diagnostics to verify a signal getting to the speedometer and that pulses are coming from the sensor. That came in handy tracking down my water problem…….
1 - 4 of 4 Posts
