1 - 9 of 9 Posts
I want a plug and play modulator for my spoiler. I do not want to make it a running light, I only want it to modulate the brake light.
thanks
I got a Kisan TailBlazer. Works great. It does have a wire to make the spoiler light a tail light but I just didn't hook it up. (It has one of those connectors that splice a wire if you want the tail light - otherwise it just plugs in.) When the brake is applied it flashes fast and slows down to a solid on. Very noticeable.
Thanks William. sounds like it will work for me.
Squating Member
CJS
is this the one that flashes three times and goes to steady on???
I don't want the one that flashes continuously...
KYBLUE said:
CJS
Yes, well, not exactly.
This one will flash three time very quickly and then goes on solid for aboout 3 seconds. Then it repeats this sequence for as long as the brakes are applied. I've been told this makes you very noticable.
Cjs, do you have to cut any wires with the Backoff? looking at their website it looked like you do.
the kissan 24 LED-D or something like that is what I put on. If you want the running light you splice one wire near the harness....otherwise for jus tthe blinking for a few seconds and then solid you just plug it in. Get the best of either world.
Simple to put in.
1 - 9 of 9 Posts
