details added-use the tip of your finger nails and just lightly push down on the top of the speaker grills, then pull out. When putting back on, use the open palm and slap at the bottom and top tab locking points. Most times you will hear the tabs snap in place. Even when they look in place this completes it. Two allens and two pull pins are at the speakers as stated, be sure when pulling the instrument panel out that the two rubber groments in the center area do not pull out of place. (twist tie, or floss tie the groments after removal ) The key cover pulls up easy, but has a wire harness with the locking connector side forward side. Be careful about the three cover plastic caps that cover the bottom of the three switches(mode,display,?) Had no problems the first few times of pulling, but this last time one cover fell out while trying to connect the harness. Had me perplexed where it come from for a few minutes. Covers are only about 3/4" square caps. When installing the screws just hand snug, do no overtighten. Nest time I think electrical tape will be added to the covers caps.
