1 - 4 of 4 Posts
Headlight will not come on unless I push the reverse button sev:shrug:eral times.??
From the forum. One cure...
Starter reverse switch this happened to me last week in Myrtle Beach at night i worked the switch a few times and lights came on Cleaned with tuner cleaner(Radio Shack) when I got home.
If you pull out on the starter/reverse switch they should come on and it will need cleaning. If they still don't come on then you have a problem with fuse #9's circuit.
Thanks for the help.Cleaned switch, but now that I think about it a while back sounded the reverse would not fully engage and sounded like the gears did not "engage."? Pushed the switch of and on started working.
1 - 4 of 4 Posts
