1 - 20 of 22 Posts
Name Tag Guy
Just got our new Nolan 103 helmets, and they are terrific. Everything everyone says and more. However, one small problem and hopefully an easy fix.
We have the J&M 584 Elite headsets installed, and everything with the speakers (comfort, etc) seems to be OK..., but I'm having a bit of difficulty with the mic. With the chin-piece in the closed (down) position, the mic is pressed fairly tight against my chin/lip. I'm sure this would become a serious annoyance after even a short ride.
The question I have is, would it be OK to trim away a bit of the styrofoam on the inside of the chin-piece to make room for the mic? Sort of like hollowing out a little pocket that would keep the mic from pressing against my mouth.
Any ideas and/or suggestions...
You must be a big headed buzzard like me! :lol: I have the exact same complaint with the N102 helmet. The way I got around the uncomfortable microphone issue was to shave down the smallest windsock that came with the mic until it was pretty much flat on both sides, with one side directly in line with the mic. You then will bend the flexible arm into an arc so it sticks above the chin guard opening where the face shield closes down and position the mic to the left of your mouth just touching your lip. The sound is great, the speech (I'm told) is clear and ok to understand by others on CB's listening to me.
good luck!
Daveo
Hi:
J&M make two headset for the Nolan 103. One is J&M part number HS-ICD279-N103 MSP $189.99. The other is part number HS-ICD584-N103 MSP $209.99. Both headsets are on J&M web site. It is www.jmcorp.com.
These headset are made expressly for Noland 103N.
Barryg1800
Does any actually READ the posts that others take the time to write? Brian already mentions he has the N103 WITH THE 584 HEADSETS! Your post is pointless! :rolleyes:
Brian,
Sounds like you're in the same boat I'm in with my Shoei. I wasn'r comfortable "digging" out a pocket on my shin bar, so right now I'm just living with the problem.
J&M does have a "thin" style boom mic designed for "Full Face" hemlets so you can attach the mic to the chin bar, but I don't think that will work with flip face helmets.
You might want to give J&M a call and ask for their help. They might have something we don't know about.
Good luck!
Name Tag Guy
That's a more complimentary description than a few others have thrown at me..., more like "fat head"... :lol::lol: Actually, we have the same problem with both helmets, and the SO has a faily slim face, but her mic presses fairly significantly on her mouth.
I have a whole box of various sized windsocks, so maybe I'll try and see if something smaller will work a bit better.
Name Tag Guy
And you point is...???
Name Tag Guy
Dont hold back, Bart..., say what's really on your mind... :lol::lol:
There's hardly a day goes by, reading one thread or another here, that I dont think exactly the same thing. And now, back to our regularly scheduled programming...
Sounds like you're in the same boat I'm in with my Shoei. I wasn't comfortable "digging" out a pocket on my shin bar, so right now I'm just living with the problem.
If it was just me, I'd probably just suffer through it, but it's the same on Val's helmet..., and when "honey" gets cranky, life ain't worth living... :lol: Dont know about your Shoei, but on the Nolan the Styrofoam in the chin-bar is quite thick, and it wouldn't take a very deep pocket to do the trick. However, that would be my last resort in case no one comes up with something worthwhile.
J&M does have a "thin" style boom mic designed for "Full Face" helmets so you can attach the mic to the chin bar, but I don't think that will work with flip face helmets.
I think you'd have cords and cables all over the place. With my luck, I'd likely strangle myself.
Good idea..., I'll give them a shout.
Got the N103's and installed Edsets, purchased the mike for full face helmets and couldn't find a way to mount it (as with some of the other flip faced helmets), so went with the old boom mics. Have the same problem and am living with it for now, but can see some removal of the foam on the chinbar in the future. Will be interested in any unusual options that don't disfigure the helmet.
Name Tag Guy
It's not much consolation, but it IS reassuring to know that I'm not the only one suffering this problem. :lol: Hopefully there will be a solution that we can all use.
Name Tag Guy
Discussion Starter · #13 ·
Try getting rid of the windsock altogether and put a piece of scotch tape over the holes on the mic. Works great
I thought of removing the wind sock altogether, but dont know how much noise might be generated, especially from the passenger's mic. Inside the helmet, it probably wouldn't be noticable, but I figure we'll be doing quite a bit of riding (especially in the summer) with the chin-bar flipped up. I do have Mic-Mutes installed and they help a LOT, so maybe it wont be a big deal to do away with the wind sock. I'll have to try the scotch tape idea. Not sure if these are noise-cancelling mics or not, though.
I have not tried it on the N 103 but ...
On my Nolan N-102 I carved a "divot" from the center of the chin plate to recess the mic
(ran the mic wire inside for the EdSet).
My install looks like this:
http://www.denvan.com/gl1800/NolanEdSetInstall/Index.htm
I'd try for a recess to solve the problem.
Dennis
Thanks for the info guys. I am purchasing a nolan 103 from sierra electronics and having the headset installed that plugs in. i will watch for this
I have this set up, got it from Sierra too.... this was the first time I've had a mic and I just thought having the mic tight against my lips was going to have to be expected for a modular helmet... I've just gotten use to it.:shrug:
Brian I have the same setup that you have with the Nolen 103 and J&M headsets. I also have a big head,:p I have the Nolen 103 XXL, with the mike I just angle it up alongside my face no problem with folks hearing me on the CB or Cell. I wouldn’t hesitate to cut an area around the mike if that is where you want to keep it. I had to cut around where my glasses go in the helmet by the speakers for it to fit comfortable.
Nolan 103 intercom problem
Brian,
Try taking a kitchen spoon and warming it up and place it on the foam area where your mic is hitting and see if you can recess that area a little bit. This worked on a Arai helmet awhile back.
Name Tag Guy
Discussion Starter · #19 ·
Another good idea... Thanks
1 - 20 of 22 Posts
