1 - 3 of 3 Posts
Try to find part number for the upper side brake hose from the secondary master cylinder to the brake pipe to PCV. I can find numbers for the brake pipe but not the hoses.
This number you have might be it. It is the line that has a rubber hose at the bottom going to one of the left brake caliper fittings then up to the top of the secondary master cylinder and continues up to the metal junction. It's actually 2 rubber hoses joined with a metal banjo fitting in the middle.
1 - 3 of 3 Posts
