1 - 11 of 11 Posts
Have new lexan windshield with a sticker glued on. I tried hair dryer, Honda cleaner, soap & water and Tulsa 502. I am at a loss, HELP
Can you get some dental floss under an edge and work it across? Just a thought. I've used it to remove sticky tape stuff.
Don't laugh but try peanut butter. Smear it all around and on the label, let it set over night, take a damp warm soft cloth and wipe it off, repeat if necessary. It works for me.
windshield
goo gone works well removing sticky glue residue. wd-40 also does a good job. I'm not sure if either of these are safe to use on windshields.
JD
creamy or chunky? :beer8:
Chunkie is ok if you chew it up first.
I would not put goo gone on that screen,it will give you fits.Never heard of peanut butter,but worth a shot.I did use :wink: cooking oil and had luck. :wink:
Curious Member
Have you tried contact cleaner or a heat gun (as opposed to a hair dryer)?
Several years ago I heard about the Peanut Butter and here it is again, just maybe there might be something here.
Young Buck
Wal-Mart carries a product in their painting section called "Oops!". It is a mild solvent that removes lots of annoying stuff. You can get a 5 or 6 ounce can for a buck and a half.
Hardly a week goes by that I don't grab that can to take care of something...
http://www.homaxproducts.com/catalog/oopsmulti.html
1 - 11 of 11 Posts
