1 - 2 of 2 Posts
Need some help on locating the correct wire for brake modulator for Kisan. I have s spoiler with the ec device so that it is a brake/running light. I need the Kisan to flash all six brake light 4 in trunk and 2 in saddle bags. any ideas :?:
Kisan makes two different brake moduators. One is spliced in line and modulates all the brake lights. The other one they make modulates only the spoiler light. Sounds like you have the in line one. You will need to remove the seat to access this wire. After removing the seat, there is a large wire bundle which runs aft near the trunk. You will see a large rubber boot over a connector. Slide the boot back and you will need the color code for the brake light. The instructions you have should indicate the color. Also, you can use a voltmeter to locate the wire. You will be able to get your electrical probes on each side of the connector to get a reading. After you locate the wire, you will need to cut it (ouch) on each side of the connector and splice the modulator in here. Works good and last a long time.
1 - 2 of 2 Posts
