I thought I’d mention that newbies would be well advised to check out some of the specialty boards...... especially if you plan to make modifications or do maintenance on your Wings.....I don’t expect you’ll find too much info on the 1833’s yet ( I’m sure the info will come as it becomes available) but there is plenty of stuff for the 1832’s.
The tech board is extremely helpfull, but the search function is not the greatest.....it can be frustrating if your looking for something in particular....there is a good chance the info your looking for is there but it can be difficult to put your finger on it.
If you use the search function, and you don’t find what your looking for......it’s probably best just to ask for the info on the General Message board and the members that have been around for a while are usually happy to help....( the odd person might suggest you learn how to use the search function....but as I’ve said...it’s not the best)
The “How to Step by Step” board has a lot of great information with pictures and thoughtful step by step instruction.
I recommend you browse through all the pages to see if there is something you might want to try.
I just posted an update on that board about a detentioning tool you can easily make to help you do a valve clearance check. The original poster ( innovator) did a great job with his step by step.....I added a few comments after building and using said tool.
Good luck finding what you need.....i guaranty the info your looking for is here!
