Honda only lists a Trunk Light 08U74-MKC-A00 KIT,TRUNK INNER LAMP, and I'm aware it requires Trunk Sub-Harness 08E86-MKC-A00 KIT,OP TRUNK SUB.
No listing for side bag lights.
If you look at the interior top of the side bags, there is a fixture location (like the trunk) for illuminating the interior of the compartments.
Have any of you installed the trunk lights in those compartments?
Is it the same part number as the trunk?
Does it require two more sub-harnesses?
Where does it plug into?
Thanks for your help in advance!
Don't know of any OEM lights for the saddlebags. Only one sub-harness can be attached.
Have done lot's of GL1800 touring since 2005, my first Goldwing. I have never needed a light for the saddle bags. A few times I needed a light at night for the trunk. I found that the simple answer is a small key chain flash light. A fixed light in the trunk still did not let me see around other items still in the trunk.
Works with the saddle bags too!
Sometimes the simplest things work the best.
Corventure Dave
