When I first got the bike last September, several people on this board suggested that the fluids be checked in case the dealer didn't top things off.
I did that. I checked everything including the final drive oil and when I put my finger in the fill hole there was oil. It wasn't dripping out but I knew it was right near the top. I even thought the oil was rather thin for final drive oil, but figured Honda put it in there, maybe it is some special oil for breaking in the final drive.
Today, with 10,000 miles on the bike, I decided to change it and get the old oil out and put in some fresh oil.
It didn't drain very long, maybe a couple of seconds, so I let it sit for over an hour.
It didn't look like much in the drain pan, so I poured it into a measuring cup, letting it sit for quite a while to drain all of it out.
I cannot believe I got less than 3 oz out of the final drive.
I refilled it and it was dripping out after I would wipe it clean, and I know it is full now.
I wonder what happened to the rest of the oil?
I am positive I checked it correctly when I first got the bike. Somehow the finger test didn't work.
The only thing I can think of is when someone gets a new bike and they remove the cap and it doesn't drip out, add some more until it does. Then you will know it is full.
