I gave him the correct answer to "his" question. Don't remember him asking about side to side adjustments. LOL... If you have more questions about light adjustments, "bubba red" can answer that also.edum43 said:How do you adjust for low beam, high beam and side to side? Reading the bubba red answer,sounds like only one for each side.He didn't say annything about how many are up fairing area.
ride safe,
edmund
Toyo.... No need to remove the fillers.Reach in under the fairing from the front of the bike.
Everyone's right headlight is a little lower than the left. It's the Correct alignment from the factory. Maybe adjusting it helps with the wobble. :roll:Toyo said:My right side bulb is lower than the left. I need to move it just a tad. If I remember correctly there is an adjuster down there? I have my tunnel fillers in so I cant see in there. Thanks.
Yep, if you live in Europe or drive on the wrong side of the road. LOL...mr.b said:Everyone's right headlight is a little lower than the left. It's the Correct alignment from the factory.
