From the Helmet Sunblocker website - Our whole business was founded on the idea of the Helmet Sunblocker™. Now internationally known, the Helmet Sunblocker™ has become the pinnacle for many riders that have found motorcycle accessories that they feel they just could not live without.
Based on the idea of the ultraviolet ray (U.V.) protectant used on airplanes, the Helmet Sunblocker™ works effectively, is cheap to maintain and installs easily using only soap and water. Instead of looking through the Helmet Sunblocker™ your eyes are below it, keeping it in your upper peripheral vision. Eye doctors have attested that it does work effectively and your own eyes will tell you that it’s doing what it’s supposed to be doing.
Also, since you install the Helmet Sunblocker™ unobtrusively inside of your helmet, you will not have to worry about wind trying to blow it off. The Helmet Sunblocker™, installed properly, will not peel off unless you deliberately pull it off. In other words, it will not fall off in your face while you ride and it can be used over and over again in separate helmets with different face shields.
Your helmet will definitely stay cooler with a Helmet Sunblocker™ installed because less U.V. and other solar radiation can penetrate through. Once installed, you can’t help but notice the green, translucent material of this product but you will grow accustomed to it after several hours of riding. We guarantee that you will accept this new addition to your helmet as a welcomed friend, instead of hostile intruder.
"Tools" Needed:
1 Bowl of Water
1 Tablespoon Liquid Dishwashing Soap
