1 - 3 of 3 Posts
Just received a used Corbin. Has the heater wiring. There is a y cable that both front and rear seat heaters plug into with the two prong plug. The other end has a black and a green wire. There are in line fuses on both these wires. Does the black go directly to the negative on the battery and the green directly to the positive on the battery? Any info would be appreciated.
allan
Chard Member
Corbin did instruct you to go directly to the aux with the + & -. If you go directly to the battery you will have a dead battery on a regular basis. :(
CORBIN SEAT
Red is right that is the way mine is hooked up.
1 - 3 of 3 Posts
