Well... I managed to take it out!!!! YEAH!!!!
I am so proud of myself... :roll:
I'd like to thank all who contributed!
The cumulative wisdom strikes again !!!! :bow::bow::bow:
How I did it:
I followed the directions from the site that I actually never saw before when I was poking around prior to ordering... THANK YOU, BigMick !!! :bow:
I took the caliper apart (disconnected and drained the banjos).
Put it in a vise, hammered in 4mm elbow hex, turn - no dice. Try again - spun out.
Drilled a 1/4" deep hole (trying my best to be centered) a bit larger and hammered in 4.5 mm hex - BINGO!!!!!! It's out !!!!:thumbup:
Took a good magnet and collected all the shavings, pushed the pucks all the way in, which cleared out the bleeder hole with whatever fluid was still inside.
Hope that helps someone!
P.S. I spoke to Mike from the Speed Bleeders Co,.
Made a suggestion to alter their instructions a bit to prevent others from falling into the same trap.
They say " screw in speed bleeder into a caliper until it seats".
Well... this "until it seats" part is what did me in (and I am sure many others before and more to come).
Seeing that the OEM bleeder nut seats flush against the caliper and that what I thought was the goal here. I thought that the resistance was from the thread locker and it REALLY DID NOT TAKE MUCH to snap.
So, I suggested that they mention that there will be a couple of threads still showing above the caliper when the bleeder is actually seated already.
Now, that I had emptied the front master cylinder prior to removing the banjo bold - I need to replace fluid and bleed the WHOLE system.
Any advise on that would be appreciated...[Should I crack open all the bleeders at the same time (front) to let the lines prime or still do one at a time?
How I did it:
